Ir para o conteúdo principal
Sony Xperia Phone - Service / Test Menu
Vídeo de Apresentação
  1. Sony Xperia Phone - Service / Test Menu, Sony Xperia Phone - Service / Test Menu: passo 1, imagem 1 %32 Sony Xperia Phone - Service / Test Menu, Sony Xperia Phone - Service / Test Menu: passo 1, imagem 2 %32 Sony Xperia Phone - Service / Test Menu, Sony Xperia Phone - Service / Test Menu: passo 1, imagem 3 %32
    • Enter the following code *#*#7378423#*#* into the dialler.
    • You can choose between:
    • - Service info
    • - Service settings
    • - Service tests
    • - Callibration
    • - Customization Settings
    I just tried this on a Sony V3+ phone and nothing happened
    Ahmad Dan-Hamidu - Responder
    Sony Xperia z3 compact does not show calibration.
    M and R Johns - Responder
    Did nothing for my pale screen with vertical white bars appering
    kevinbuk - Responder
    Hallo, bei mir öffnet sich das Service Menü nur mit drei Funktionen. Calibration und Customization Settings fehlen. Habe das Z5 gebraucht gekauft. Wie komme ich an die anderen Funktionen. Muss das Gerät zurücksetzten da es ständig neu startet. Danke
    Jeppitsme - Responder
    was bedeuten all die Einträge im einzelnen? Wie löse ich damit den Raketenstart aus?
    ein Stein - Responder
    I have sony xperia x performance and it worked
    Maleesha Priyanjana - Responder
Linha de Chegada
78 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.308 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.535 guias
229 comentários
Hi, when I dial the number it says this is not an emergency number, please help
Kerel Man - Responder
hi Kerel,
you dont have to dial that number.
Just type on your phone, when u enter last star symbol itself the options will display !
Adarsh J PREM -
Yup, I also tried it on a Sony V3+ and nothing happened.
Ahmad Dan-Hamidu -
Bonjour, Je suis ce téléphone
Je veux décompresser la lame de l'écran (lui toutes les routes utilisées, mais sans succès)
sony ericsson x 10 i
typ :aad 3880065-bv aaab
fcc id : py7a3880056 cb5
ic : 4170b-a 3880056 10w22
si :1232 -4306
s/n : cb511kbprt
imei :35941903-786718-0
merci
hichame42 - Responder
*#*#7378423#*#* ؟؟؟؟؟؟؟؟؟؟؟؟
Il ne sert à rien
si :1232 -4306
s/n : cb511kbprt
merci
J'ai un téléphone sony xperia ST26i ont expérimenté plusieurs solutions pour ouvrir l'écran, mais en vain
zoubirjusticier - Responder
I can't even get into service menu
Mysterious Keeper - Responder
I gave the no but I could not get into service menu
farzi -
Bon soir
J'ai un téléphone sony Xperia z c6603 et j'ai améliorer l'android kitkat à lollipop mais j'ai un problème dans le réglage qui demande le mot de passe pour l'entrer.aidez-moi svp
Lamine - Responder
My mobile is damaged I want service
Sumer - Responder
very nice share, thank you
andreana - Responder
just got xperia c4 dual sim, water damage and the touch pannel not working. work on touchscreen connector a little bit with soldering iron+hot air, now touch pannel works perfectly. just need to make sure all all touch pannel surface are works. using your code for testing, done. thank you for the code
I dial the code and nothing appear
XANDRA BATSA - Responder
Para el xperia x f5121 tambien sirve?
Natalia Romero - Responder
My phone setting in not work
Plz help me
Tarun Kothari - Responder
I have forgotten my private opening code how to enter
ivar.norby - Responder
thanks for this excellent post, i’ve written something similar here > Sony Xperia Secret Codes
Gadget Website - Responder
Como saber si se ha usado algúna ves la 2da sim aun que no este montada en ese momento?
Carlos - Responder
How can i know if someone has been using and removing sim 2 to make phone calls when is unmounted? Xperia
Carlos - Responder
Testgfcgffgvhhhgg
cyberov50 - Responder
Hgidididisisjhdhdbdbdbd
come faccio a cambiare imei
Luigi Mantione - Responder
il mio phone e il seguente xperia L1
I try the freedrwing test.other side not function
Wt should i do?
christina - Responder
Ich habe ein gut erhaltenes xperia z5 premium gekauft.
Kann ich irgendwie die Gesamtlaufzeit ermitteln.
Ich meine eine Zahl, die nicht durch Reset wieder auf 0 gesetzt wird sondern die die Laufzeit seit dem ersten Booten anzeigt?
Maha Hridaya - Responder
unable to unlock screen lock on VODAPHONE Sony XPERIA D2203 forgot my pin no star or hash facility on screen lock. looking for a code to open as there is no program to access phone
Derrick Andreasen - Responder
code is not working to my zony xperia xz2 phone.solution please..
dinukalakmal106 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 20
Últimos 7 dias: 139
Últimos 30 dias: 771
Duração total: 526,167
