Introdução
This guide is for removing the 3.5mm headphone jack from the Sony Xperia M4 Aqua in the event that it needs to be replaced.
O que você precisa
Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
Release all connectors connecting to the motherboard.
Pry the motherboard up from the left side with the plastic pry tool and remove it.
With your fingers, or nylon spudger if necessary, remove headphone jack fastening cover, casing, and sticker.
7 outras pessoas executaram este guia.
2 comentários
"This is not Xperia Z3
This is a guide of the M4 Aqua" - Faruk
Just thought it could be told in english as well, cheerio!
