Ir para o conteúdo principal
Sony Xperia L2 LTE Motherboard Replacement
O que você precisa
  1. Sony Xperia L2 LTE Motherboard Replacement, Battery: passo 1, imagem 1 %32 Sony Xperia L2 LTE Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Sony Xperia L2 LTE Motherboard Replacement: passo 2, imagem 1 %32 Sony Xperia L2 LTE Motherboard Replacement: passo 2, imagem 2 %32 Sony Xperia L2 LTE Motherboard Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to pry the back case of the phone off.
    • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
  3. Sony Xperia L2 LTE Motherboard Replacement: passo 3, imagem 1 %32
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
  4. Sony Xperia L2 LTE Motherboard Replacement: passo 4, imagem 1 %32 Sony Xperia L2 LTE Motherboard Replacement: passo 4, imagem 2 %32
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
    • Be careful not to jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  5. Sony Xperia L2 LTE Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Unclip circuit connectors from phone to motherboard.
  6. Sony Xperia L2 LTE Motherboard Replacement: passo 6, imagem 1 %32 Sony Xperia L2 LTE Motherboard Replacement: passo 6, imagem 2 %32 Sony Xperia L2 LTE Motherboard Replacement: passo 6, imagem 3 %32
    • Use blue plastic opening tool to pry off the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 475
