Introdução
E2104, E2105, E2115, E2124
How to disassemble, take apart the device and change / replace broken touch screen glass digitizer, LCD
O que você precisa
Vídeo de Apresentação
Remove the back cover and any installed SIM and memory cards.
There are 8x black screws Torx T4. Remove them.
Disconnect the touch screen flex cable.
Under it is the LCD flex cable. Disconnect it also.
Cover the glass with a scotch tape.
Warm the glass for about minute.
With a cutter lift a little the glase to make a room for the plastic tool.
12 outras pessoas executaram este guia.
4 comentários
Grazie! È stato davvero utilissimo. :)
Doesn't the original glass and digitalizer come out with its biadesive?
