Ir para o conteúdo principal
Sony Xperia E4 Touch Screen Glass / LCD Display Replacement
O que você precisa
Vídeo de Apresentação
  1. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Battery Cover: passo 1, imagem 1 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Battery Cover: passo 1, imagem 2 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Battery Cover: passo 1, imagem 3 %32
    • Remove the back cover and any installed SIM and memory cards.
    • There are 8x black screws Torx T4. Remove them.
  2. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 2, imagem 1 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 2, imagem 2 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 2, imagem 3 %32
    • Remove the small black rubber at the lower left corner.
    • Under it is the battery flex cable, disconnect it.
  3. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 3, imagem 1 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 3, imagem 2 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 3, imagem 3 %32
    • Use a plastic tool to separate the middle frame.
    • The battery is glued to the middle frame with an adhesive tape.
    • Loudspeaker
  4. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Logic Board: passo 4, imagem 1 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Logic Board: passo 4, imagem 2 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Logic Board: passo 4, imagem 3 %32
    • Disconnect the touch screen flex cable.
    • Under it is the LCD flex cable. Disconnect it also.
  5. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 5, imagem 1 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 5, imagem 2 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 5, imagem 3 %32
    • Remove the logic board.
    • Be careful for the flex cables.
  6. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Touch Screen Glass / LCD Display: passo 6, imagem 1 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Touch Screen Glass / LCD Display: passo 6, imagem 2 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Touch Screen Glass / LCD Display: passo 6, imagem 3 %32
    • Cover the glass with a scotch tape.
    • Warm the glass for about minute.
    • With a cutter lift a little the glase to make a room for the plastic tool.
  7. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 7, imagem 1 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 7, imagem 2 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Carefully put the plastic tool between the glass and the LCD.
    • The tool must be thin, you can use also a plastic card.
    • Periodically warm the glass.
    • Remove the display frame.
  8. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 8, imagem 1 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 8, imagem 2 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 8, imagem 3 %32
    • Use only plastic tools and don't force the LCD.
  9. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 9, imagem 1 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 9, imagem 2 %32 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 9, imagem 3 %32
    • Install adhesive tape.
    • It's easier if you order your touch screen together with adhesive sticker.
    • Start with the reassembling.
  10. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: passo 10, imagem 1 %32
    • That's all.
Conclusão
12 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.368 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.468 guias
4 comentários
Grazie! È stato davvero utilissimo. :)
Andrea DePa - Responder
Doesn't the original glass and digitalizer come out with its biadesive?
marco bigoni - Responder
First Timer here:
I've followed this and replaced the cracked screen (the clear bit).
But it still looks cracked; could it be that I have a cracked LCD thingy as well? (is that the black bit?).
If so what's the part number for that?
MartynJ - Responder
Why don't you just buy the screen which has the lcd and digitiser already assembled? That will save you a lot of hassle for only a few £'s more :)
Clems - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 20,258
