Ir para o conteúdo principal
Sony XPERIA Tablet Z Screen Replacement
O que você precisa
  1. Sony XPERIA Tablet Z Screen Replacement, Screen: passo 1, imagem 1 %32 Sony XPERIA Tablet Z Screen Replacement, Screen: passo 1, imagem 2 %32 Sony XPERIA Tablet Z Screen Replacement, Screen: passo 1, imagem 3 %32
    • Remove the back cover by lifting up one corner using the plastic opening tool, and then removing the adhesive around the cover.
  2. Sony XPERIA Tablet Z Screen Replacement: passo 2, imagem 1 %32 Sony XPERIA Tablet Z Screen Replacement: passo 2, imagem 2 %32 Sony XPERIA Tablet Z Screen Replacement: passo 2, imagem 3 %32
    • Gently separate the gold ribbon cable from the back side by lifting up with plastic opening tool and separating from the adhesive.
    • Separate the black ribbon cable from the back of screen by lifting up with a plastic opening tool.
  3. Sony XPERIA Tablet Z Screen Replacement: passo 3, imagem 1 %32
    • Use a hairdryer, heat gun, or something suitable to heat the edge of the screen to soften the adhesive holding the screen.
    • Only heat enough to loosen the adhesive but not damage the tablet.
  4. Sony XPERIA Tablet Z Screen Replacement: passo 4, imagem 1 %32
    • Gently pry the edge of the screen working around while heating.
  5. Sony XPERIA Tablet Z Screen Replacement: passo 5, imagem 1 %32
    • Clean adhesive from perimeter of frame to prepare for new screen.
Conclusão
8 outras pessoas executaram este guia.
Gustavo Correa
Membro desde: 07/11/17
373 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S5-G1, Harley Summer 2017 Membro de IUPUI, Team S5-G1, Harley Summer 2017
IUPUI-HARLEY-SU17S5G1
Membros da 4
Autoria de 3 guias
5 comentários
اريدشراءاريدشراءشاشه جديده
kore ares - Responder
Do you need adhesive to attach new screen, & if so, what do you use?
Martha Morrison - Responder
i would also like to know what adhesive you use to reatach the screen. thanks
Blaze - Responder
Wooo its self explanatory.Good work
Duncan Mwaniki - Responder
Where do I get the Screen if I'm in South Africa
Thembekile Nizel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 21
Últimos 30 dias: 107
Duração total: 7,084
