O que você precisa
Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
Insert plastic opening tool in the corner of device and slide along edges to separate adhesive
Remove cover
Locate the SD card reader in the bottom left hand corner
Remove all screws connecting the metal plate to the device.
After all the screws have been removed lift the circuit board up to wiggle free.
After Wiggled free place the tweezers on the piece of electrical tape connecting it to the device.
Once placed there lift up and disconnect the SD card reader from the device.
Uma outra pessoa concluiu este guia.
