Ir para o conteúdo principal
Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement
O que você precisa
  1. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: passo 1, imagem 1 %32 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: passo 1, imagem 2 %32 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
    • Remove cover
  2. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: passo 2, imagem 1 %32 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: passo 2, imagem 2 %32 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: passo 2, imagem 3 %32
    • Remove tape connecting front camera to motherboard and then disconnect the camera from the port.
    • Lift the camera from the right and simply wiggle out of the slot.
  3. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: passo 3, imagem 1 %32 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: passo 3, imagem 2 %32 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: passo 3, imagem 3 %32
    • Disconnect the back camera from the port located in the upper right corner.
    • Lift up the camera cable using the tweezers.
    • Wiggle out camera from the slot.
Conclusão
Martin Luna
Membro desde: 09/24/14
1.873 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 15-6, Remmell Fall 2014 Membro de USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 2,972
