Ir para o conteúdo principal
Sony XAV-AX100 Motherboard Replacement
O que você precisa
  1. Sony XAV-AX100 Motherboard Replacement, USB Cable: passo 1, imagem 1 %32 Sony XAV-AX100 Motherboard Replacement, USB Cable: passo 1, imagem 2 %32 Sony XAV-AX100 Motherboard Replacement, USB Cable: passo 1, imagem 3 %32
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 Motherboard Replacement: passo 2, imagem 1 %32 Sony XAV-AX100 Motherboard Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 Motherboard Replacement: passo 3, imagem 1 %32
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 Motherboard Replacement: passo 4, imagem 1 %32
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 Motherboard Replacement: passo 5, imagem 1 %32 Sony XAV-AX100 Motherboard Replacement: passo 5, imagem 2 %32 Sony XAV-AX100 Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
  6. Sony XAV-AX100 Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Sony XAV-AX100 Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  7. Sony XAV-AX100 Motherboard Replacement: passo 7, imagem 1 %32 Sony XAV-AX100 Motherboard Replacement: passo 7, imagem 2 %32 Sony XAV-AX100 Motherboard Replacement: passo 7, imagem 3 %32
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
Conclusão
Abdulaziz Redha
Membro desde: 02/22/18
741 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G5, Cagle Spring 2018 Membro de USF Tampa, Team S1-G5, Cagle Spring 2018
USFT-CAGLE-S18S1G5
Membros da 2
Autoria de 5 guias
Um comentário
Where to buy the motherboard ?
B.Keat - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 1,544
