Introdução
By following this repair guide, you will be able to replace the full Head Display; thus, providing yourself with better visuals and imaging.
O que você precisa
Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
Remove the ten 3.5mm Phillips #0 screws from the back plate.
Disconnect the display power cable from the motherboard.
Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
6 outras pessoas executaram este guia.
3 comentários
Where do you get a replacement screen?
I need one for a xav 3005 db
Thank you very much for this great write up.
However after having performed it, if all you are doing is replacing the screen, then steps 1, 4, 5 and 7 are actually completely unnecessary . There is no need to remove the back panel or the motherboard.
but thank you nonetheless for having shown the way.
I need to get a replacement screen for a Sony xav 1500 any idea of a cheap place?
