Introdução
By following this repair guide, you will be able to replace your Screen Motherboard. Therefore, your device will take less time processing high resolution images and information.
O que você precisa
Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
Remove the ten 3.5mm Phillips #0 screws from the back plate.
Disconnect the display power cable from the motherboard.
Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
Remove the four 3.5mm Phillips #0 screws from the display board.
Remove the black tape using a precise tweezer.
Remove the 3.5mm Phillips #0 screw from underneath the tape.
Uma outra pessoa concluiu este guia.
