Ir para o conteúdo principal
Sony Walkman WM-AF48 Film Revolver Band Replacement
O que você precisa
  1. Sony Walkman WM-AF48 Film Revolver Band Replacement, Getting started: passo 1, imagem 1 %32
    • Remove any batteries or cassettes from the Walkman.
  2. Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: passo 2, imagem 1 %32 Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: passo 2, imagem 2 %32 Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: passo 2, imagem 3 %32
    • Using a spudger, separate the back cover from the front.
    • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
  3. Sony Walkman WM-AF48 Film Revolver Band Replacement, Replace the band: passo 3, imagem 1 %32
    • Replace the band, ensuring that it wraps around both large plastic revolvers and the small metal one.
    Would be useful to see the path of the band around these parts.
    Rus Woodward - Responder
  4. Sony Walkman WM-AF48 Film Revolver Band Replacement, Belt track: passo 4, imagem 1 %32
    • This picture shows how the belt was set when I opened a Walkman WM-FX10.
    • I think you can rely on the same arrangement in other Walkman's
    I'm looking at a Sony WM-FX195 and the arrangement appears to be totally different. There's a wheel on the left (the same) but on the right there's only the motor. The right hand wheel is not present and the belt is very loose.
    jookieapc - Responder
Conclusão
8 outras pessoas executaram este guia.
Equipe
3 comentários
"How to replace the band":
Step 1: Open it.
Step 2: Replace the band.
Really? That's it?! Not very useful.
No Thanks - Responder
I need to know the belt track. I'm thinking there is a particular path the belt must follow. Do you know it? Your photo shows no belt (band).
jcalla704 - Responder
Helped. Wanted an idea of how to open, before breaking it!
Troyf - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 28
Últimos 30 dias: 105
Duração total: 17,306
