Ir para o conteúdo principal
Sony Walkman WM-AF48 Film Revolver Band Replacement
O que você precisa
  1. Sony Walkman WM-AF48 Film Revolver Band Replacement, Getting started: passo 1, imagem 1 %32
    • Remove any batteries or cassettes from the Walkman.
  2. Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: passo 2, imagem 1 %32 Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: passo 2, imagem 2 %32 Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: passo 2, imagem 3 %32
    • Using a spudger, separate the back cover from the front.
    • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
  3. Sony Walkman WM-AF48 Film Revolver Band Replacement, Replace the band: passo 3, imagem 1 %32
    • Replace the band, ensuring that it wraps around both large plastic revolvers and the small metal one.
  4. Sony Walkman WM-AF48 Film Revolver Band Replacement, Belt track: passo 4, imagem 1 %32
    • This picture shows how the belt was set when I opened a Walkman WM-FX10.
    • I think you can rely on the same arrangement in other Walkman's
Conclusão
8 outras pessoas executaram este guia.
Equipe
3Comentários do guia
"How to replace the band":
Step 1: Open it.
Step 2: Replace the band.
Really? That's it?! Not very useful.
No Thanks - Responder Compartilhar
I need to know the belt track. I'm thinking there is a particular path the belt must follow. Do you know it? Your photo shows no belt (band).
jcalla704 - Responder Compartilhar
Helped. Wanted an idea of how to open, before breaking it!
Troyf - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 29
Últimos 30 dias: 110
Ao todo: 19,554
