Ir para o conteúdo principal
Sony Walkman NWZ-S764 Bluetooth module Replacement
O que você precisa
  1. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: passo 1, imagem 1 %32 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: passo 1, imagem 2 %32 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: passo 1, imagem 3 %32
    • Remove the two black 6.4mm Phillips screws from the back of the device.
  2. Sony Walkman NWZ-S764 Bluetooth module Replacement: passo 2, imagem 1 %32 Sony Walkman NWZ-S764 Bluetooth module Replacement: passo 2, imagem 2 %32 Sony Walkman NWZ-S764 Bluetooth module Replacement: passo 2, imagem 3 %32
    • Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
  3. Sony Walkman NWZ-S764 Bluetooth module Replacement: passo 3, imagem 1 %32 Sony Walkman NWZ-S764 Bluetooth module Replacement: passo 3, imagem 2 %32
    • Remove the two 2.8 mm phillips screws located on either side of the device near the top.
  4. Sony Walkman NWZ-S764 Bluetooth module Replacement: passo 4, imagem 1 %32 Sony Walkman NWZ-S764 Bluetooth module Replacement: passo 4, imagem 2 %32
    • Carefully pull the top piece away from the device.
  5. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: passo 5, imagem 1 %32 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: passo 5, imagem 2 %32 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: passo 5, imagem 3 %32
    • Use the flat end of the spudger to flip up the retaining flap for the bluetooth module.
    • Be sure to lift up on the retaining flap, and not the socket itself.
  6. Sony Walkman NWZ-S764 Bluetooth module Replacement: passo 6, imagem 1 %32 Sony Walkman NWZ-S764 Bluetooth module Replacement: passo 6, imagem 2 %32 Sony Walkman NWZ-S764 Bluetooth module Replacement: passo 6, imagem 3 %32
    • Remove the two 1.8mm silver Phillips screws on the Bluetooth module.
    • Lift up on and remove the Bluetooth module.
    • The ribbon cable must first be removed in order to access the highlighted screw.
Conclusão
John Ferguson
Membro desde: 01/21/15
657 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 4-2, Brown Winter 2015 Membro de USF Tampa, Team 4-2, Brown Winter 2015
USFT-BROWN-W15S4G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 639
