Ir para o conteúdo principal
Sony Walkman NWZ-S764 Audio Port Replacement
O que você precisa
  1. Sony Walkman NWZ-S764 Audio Port Replacement, Removing the back cover: passo 1, imagem 1 %32 Sony Walkman NWZ-S764 Audio Port Replacement, Removing the back cover: passo 1, imagem 2 %32 Sony Walkman NWZ-S764 Audio Port Replacement, Removing the back cover: passo 1, imagem 3 %32
    • Remove the two black 6.4mm Phillips screws from the back of the device.
  2. Sony Walkman NWZ-S764 Audio Port Replacement: passo 2, imagem 1 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 2, imagem 2 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 2, imagem 3 %32
    • Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
  3. Sony Walkman NWZ-S764 Audio Port Replacement: passo 3, imagem 1 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 3, imagem 2 %32
    • Remove the two 2.8 mm phillips screws located on either side of the device near the top.
  4. Sony Walkman NWZ-S764 Audio Port Replacement: passo 4, imagem 1 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 4, imagem 2 %32
    • Carefully pull the top piece away from the device.
  5. Sony Walkman NWZ-S764 Audio Port Replacement, Audio Port: passo 5, imagem 1 %32 Sony Walkman NWZ-S764 Audio Port Replacement, Audio Port: passo 5, imagem 2 %32 Sony Walkman NWZ-S764 Audio Port Replacement, Audio Port: passo 5, imagem 3 %32
    • Remove the two 2.8mm silver Phillips screws on the sides of the frame.
    • The two 2.8mm screws are on each side of the device.
    • Insert a plastic prying tool between the bottom of the case and the motherboard.
    • Pry up the assembly and lift it away from the case.
  6. Sony Walkman NWZ-S764 Audio Port Replacement: passo 6, imagem 1 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 6, imagem 2 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 6, imagem 3 %32
    • Remove the yellow tape from the battery and volume control module.
    • Save tape for reassembly.
  7. Sony Walkman NWZ-S764 Audio Port Replacement: passo 7, imagem 1 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 7, imagem 2 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 7, imagem 3 %32
    • Use a prying tool to pry under the volume control module.
    • This module is glued on, using too much force may damage or warp the module.
  8. Sony Walkman NWZ-S764 Audio Port Replacement: passo 8, imagem 1 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 8, imagem 2 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 8, imagem 3 %32
    • Remove the tape from EMF shield and the LCD housing.
    • Lift up on the volume control ribbon.
  9. Sony Walkman NWZ-S764 Audio Port Replacement: passo 9, imagem 1 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 9, imagem 2 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 9, imagem 3 %32
    • Insert a plastic opening tool under the battery and lift up to remove it.
    • The battery is glued on, too much force may damage the battery casing.
    • The battery is soldered to the motherboard, care should be taken to not place too much stress on the wires.
  10. Sony Walkman NWZ-S764 Audio Port Replacement: passo 10, imagem 1 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 10, imagem 2 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 10, imagem 3 %32
    • Remove the black shielding tape from above the Hard Drive.
    • Peel the foam cover away from the hard drive.
    • Use a plastic opening tool to remove the EMF chip from the motherboard.
    • The hard drive is soldered onto the device. Be careful not to pull too hard on the hard drive.
  11. Sony Walkman NWZ-S764 Audio Port Replacement: passo 11, imagem 1 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 11, imagem 2 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 11, imagem 3 %32
    • Remove the plastic bracket by pushing up with your thumb to expose the display connection.
  12. Sony Walkman NWZ-S764 Audio Port Replacement: passo 12, imagem 1 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 12, imagem 2 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 12, imagem 3 %32
    • Use the flat end of a spudger to flip up the retaining flap on the audio jack module.
  13. Sony Walkman NWZ-S764 Audio Port Replacement: passo 13, imagem 1 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 13, imagem 2 %32
    • Peel back the ribbon for the audio jack and remove the 1.8mm silver Phillips screw.
  14. Sony Walkman NWZ-S764 Audio Port Replacement: passo 14, imagem 1 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 14, imagem 2 %32 Sony Walkman NWZ-S764 Audio Port Replacement: passo 14, imagem 3 %32
    • Remove the mic casing by pushing up and in.
    • Remove the headphone jack and the bottom casing.
Conclusão
John Ferguson
Membro desde: 01/21/15
657 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 4-2, Brown Winter 2015 Membro de USF Tampa, Team 4-2, Brown Winter 2015
USFT-BROWN-W15S4G2
Membros da 4
Autoria de 6 guias
2 comentários
Awesome! But where did you get the port itself?
heaver - Responder
Yeah where do I get a replacement jack?
petermedz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 2,391
