Introdução
This guide will take you through 6 simple steps to removing your circuit board. For reattachment, simply follow the steps in reverse order.
O que você precisa
Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
First, you must remove the black tape on the circuit board.
Next, pull up on the red and gold band until it detaches from the chip.
Quase terminado!
For reassembling your device, follow the instructions in reverse.
Conclusão
