Ir para o conteúdo principal
Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement
O que você precisa
  1. Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement, Battery: passo 1, imagem 1 %32 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement, Battery: passo 1, imagem 2 %32 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement, Battery: passo 1, imagem 3 %32
    • Remove the four 5 mm screws in the right using a Phillips #00 screwdriver.
    • Remove the speaker panel to reveal the battery.
  2. Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 2, imagem 1 %32 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 2, imagem 2 %32
    • Unplug the battery with tweezers
  3. Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 3, imagem 1 %32 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 3, imagem 2 %32 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 3, imagem 3 %32
    • Gently remove the battery from the device using the plastic spudger.
  4. Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement, Volume & Noise Cancelling Control Button: passo 4, imagem 1 %32 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement, Volume & Noise Cancelling Control Button: passo 4, imagem 2 %32 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement, Volume & Noise Cancelling Control Button: passo 4, imagem 3 %32
    • Unscrew the two 3 mm screws retaining the circuit board to the headphones.
    • Carefully remove the circuit board with the plastic prying tool.
  5. Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 5, imagem 1 %32 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 5, imagem 2 %32 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 5, imagem 3 %32
    • Next, use the prying tool to remove the buttons.
  6. Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 6, imagem 1 %32
    • Remove buttons and replace.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 25
Duração total: 63
