Ir para o conteúdo principal
Sony WH-CH720N Speaker Replacement
O que você precisa
  1. Sony WH-CH720N Speaker Replacement, Earmuff: passo 1, imagem 1 %32
    • Place the headphones down on a table, and orient them in this way.
  2. Sony WH-CH720N Speaker Replacement: passo 2, imagem 1 %32 Sony WH-CH720N Speaker Replacement: passo 2, imagem 2 %32 Sony WH-CH720N Speaker Replacement: passo 2, imagem 3 %32
    • Remove the earmuff.
    • Check introductions to ensure you remove the correct side earmuff for each repair guide!
  3. Sony WH-CH720N Speaker Replacement, Speaker: passo 3, imagem 1 %32 Sony WH-CH720N Speaker Replacement, Speaker: passo 3, imagem 2 %32
    • Remove the four 5 mm screws holding the speaker housing onto the headphones.
    • Move the now detached speaker housing to the side, being careful of the wires.
  4. Sony WH-CH720N Speaker Replacement: passo 4, imagem 1 %32 Sony WH-CH720N Speaker Replacement: passo 4, imagem 2 %32
    • On the backside of the speaker housing, remove the four 3 mm screws to detach the panel.
  5. Sony WH-CH720N Speaker Replacement: passo 5, imagem 1 %32 Sony WH-CH720N Speaker Replacement: passo 5, imagem 2 %32 Sony WH-CH720N Speaker Replacement: passo 5, imagem 3 %32
    • With the speaker panel removed, desolder the wires connecting the speaker.
    • Use a heat gun to loosen the glue around the speaker inside the housing.
    • Finally, take the metal prying tool, and carefully remove the speaker.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 36
Duração total: 77
