Introdução
This repair guide details how to replace the USB-C charging port on the left side of the Sony WH-CH720N. This is necessary in the event of bending/ breaking the charging port, or failure to charge.
Caution when using soldering iron as the end is HOT.
O que você precisa
Use a Philips #00 screwdriver to remove the four 5 mm screws from the left driver housing.
Uma outra pessoa concluiu este guia.
