Ir para o conteúdo principal
Sony WH-CH700N Headphone Pad Cover Replacement
O que você precisa
  1. Sony WH-CH700N Headphone Pad Cover Replacement, Headphone Pad Cover: passo 1, imagem 1 %32
    • Identify the free edge of the ear pad.
  2. Sony WH-CH700N Headphone Pad Cover Replacement: passo 2, imagem 1 %32 Sony WH-CH700N Headphone Pad Cover Replacement: passo 2, imagem 2 %32 Sony WH-CH700N Headphone Pad Cover Replacement: passo 2, imagem 3 %32
    • Gently pull the free edge up.
    • Slight pressure is needed, but there is no glue.
    • Fully remove the ear pad.
    • If yours are more deteriorated, make sure to remove all excess material.
  3. Sony WH-CH700N Headphone Pad Cover Replacement: passo 3, imagem 1 %32
    • Repeat with the other side.
  4. Sony WH-CH700N Headphone Pad Cover Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • Gently wipe the exposed surface with an alcohol swab or microfiber cloth.
    • Do not scrub hard in order to avoid damaging the headphones.
  5. Sony WH-CH700N Headphone Pad Cover Replacement: passo 5, imagem 1 %32
    • Identify the wider part of the headphone pad.
  6. Sony WH-CH700N Headphone Pad Cover Replacement: passo 6, imagem 1 %32 Sony WH-CH700N Headphone Pad Cover Replacement: passo 6, imagem 2 %32 Sony WH-CH700N Headphone Pad Cover Replacement: passo 6, imagem 3 %32
    • Find the lip of the leather replacement pad.
    • Line up the new ear pad with one side of the exposed headphones, wider end towards the top.
    • Gently stretch one end of the ear pad over one end of the headphone.
    • You can anchor on the top of the ear pad by tilting the headphone out at an angle.
  7. Sony WH-CH700N Headphone Pad Cover Replacement: passo 7, imagem 1 %32 Sony WH-CH700N Headphone Pad Cover Replacement: passo 7, imagem 2 %32 Sony WH-CH700N Headphone Pad Cover Replacement: passo 7, imagem 3 %32
    • Work your way around the ear pad, pulling the leather over the lip.
    • Pull from the inside out so that the leather catches on the lip.
    • You can use your whole hand as a grip to make sure that the leather does not slip off.
  8. Sony WH-CH700N Headphone Pad Cover Replacement: passo 8, imagem 1 %32 Sony WH-CH700N Headphone Pad Cover Replacement: passo 8, imagem 2 %32
    • Repeat on the other side of the headphones.
Linha de Chegada
3 outras pessoas executaram este guia.
Jackson Inagi
Membro desde: 01/30/23
193 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 2-1, Johann Winter 2023 Membro de Cal Poly, Team 2-1, Johann Winter 2023
CPSU-JOHANN-W23S2G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 29
Últimos 30 dias: 152
Duração total: 1,610
