Ir para o conteúdo principal
Sony Vaio VPCW21FX Keyboard Replacement
O que você precisa
  1. Sony Vaio VPCW21FX Keyboard Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio VPCW21FX Keyboard Replacement, Battery: passo 1, imagem 2 %32 Sony Vaio VPCW21FX Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio VPCW21FX Keyboard Replacement: passo 2, imagem 1 %32 Sony Vaio VPCW21FX Keyboard Replacement: passo 2, imagem 2 %32 Sony Vaio VPCW21FX Keyboard Replacement: passo 2, imagem 3 %32
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: passo 3, imagem 2 %32 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: passo 3, imagem 3 %32
    • Open the Lid of the laptop
    • Then using they pry tool to carefully remove the plastic cover around the keyboard
    • It helps to pry from one of the larger keys as they have more room to fit the tool in
  4. Sony Vaio VPCW21FX Keyboard Replacement: passo 4, imagem 1 %32 Sony Vaio VPCW21FX Keyboard Replacement: passo 4, imagem 2 %32 Sony Vaio VPCW21FX Keyboard Replacement: passo 4, imagem 3 %32
    • Close the lid and flip the laptop over
    • Loosen but do not remove the screw on center panel and remove Panel.
  5. Sony Vaio VPCW21FX Keyboard Replacement: passo 5, imagem 1 %32 Sony Vaio VPCW21FX Keyboard Replacement: passo 5, imagem 2 %32
    • Remove the three 5mm screws that are holding in the keyboard.
  6. Sony Vaio VPCW21FX Keyboard Replacement: passo 6, imagem 1 %32 Sony Vaio VPCW21FX Keyboard Replacement: passo 6, imagem 2 %32 Sony Vaio VPCW21FX Keyboard Replacement: passo 6, imagem 3 %32
    • Flip laptop over again and open the lid
    • Lift up the keyboard from the top and lean it toward you to expose the connector on the back
    • Grab the wire from the keyboard close to the connector and pull carefully to the left to disconnect it from the laptop.
Conclusão
Nicholas Corcoran
Membro desde: 03/08/17
401 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 25
Duração total: 2,265
