Introdução
Can you not hear any audio through your headphones? Replacing the headphone jack may take quite a few steps, but is simple to do.
O que você precisa
Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
Place the laptop upside down with the bottom panel facing upwards.
Locate the screw that holds the small panel covering your laptop's Ram. This panel should be in the dead center of your laptop.
Unscrew the screw and remove the panel.
