Ir para o conteúdo principal
Sony Vaio VPCW211AX Fan Replacement
O que você precisa
  1. Sony Vaio VPCW211AX Fan Replacement, Keyboard: passo 1, imagem 1 %32
    • Start with the laptop face up on a flat surface.
  2. Sony Vaio VPCW211AX Fan Replacement: passo 2, imagem 1 %32
    • Open the laptop with the keyboard facing you.
  3. Sony Vaio VPCW211AX Fan Replacement: passo 3, imagem 1 %32 Sony Vaio VPCW211AX Fan Replacement: passo 3, imagem 2 %32
    • Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
    • Be careful around the edges; work your way around the keyboard until all of it is detached.
    • There will be a ribbon cable attached to the bottom of the keyboard. Be sure not to rip the cable when lifting the keyboard from the laptop frame.
  4. Sony Vaio VPCW211AX Fan Replacement: passo 4, imagem 1 %32 Sony Vaio VPCW211AX Fan Replacement: passo 4, imagem 2 %32
    • Carefully detach the ribbon from the base of the computer with your hands.
    • Remove the keyboard.
  5. Sony Vaio VPCW211AX Fan Replacement, Fan: passo 5, imagem 1 %32
    • Use a Philips #0 screwdriver to remove the 7 top case screws.
  6. Sony Vaio VPCW211AX Fan Replacement: passo 6, imagem 1 %32
    • Using a metal spudger, pry open at the seams.
    • Open the gray top of the laptop from the base black portion.
    • Slide the spudger along the seam, and then carefully open the top.
  7. Sony Vaio VPCW211AX Fan Replacement: passo 7, imagem 1 %32 Sony Vaio VPCW211AX Fan Replacement: passo 7, imagem 2 %32
    • Open the top carefully without disconnecting the two parts.
    • Be mindful and careful of the ribbon cable attaching the two parts together.
  8. Sony Vaio VPCW211AX Fan Replacement: passo 8, imagem 1 %32
    • Use a Philips #0 screwdriver to unscrew the 4 heatsink screws.
  9. Sony Vaio VPCW211AX Fan Replacement: passo 9, imagem 1 %32
    • If there is electrical tape, remove it with your finger.
  10. Sony Vaio VPCW211AX Fan Replacement: passo 10, imagem 1 %32
    • Using the plastic opening tool, pry up the unscrewed fan.
  11. Sony Vaio VPCW211AX Fan Replacement: passo 11, imagem 1 %32 Sony Vaio VPCW211AX Fan Replacement: passo 11, imagem 2 %32
    • The fan will still be attached by a small red and yellow wire, with your fingers detach this carefully.
    • Remove the fan.
Conclusão
Uma outra pessoa concluiu este guia.
Giselle Dougan
Membro desde: 01/31/18
760 Reputação
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 687
