Introdução
The disk drive replacement is intended to show a simple way to remove and replace a disk drive.
Note: Do not pull disk drive out with force, as it can damage disk drive panel.
O que você precisa
Remove the 9mm Phillips #1 screw holding the disk drive in place.
Remove the 9mm screw near the memory stick.
Uma outra pessoa concluiu este guia.
