Ir para o conteúdo principal
Sony Vaio VPCEL17FX Disc Drive Replacement
O que você precisa
  1. Sony Vaio VPCEL17FX Disc Drive Replacement, Disc Drive: passo 1, imagem 1 %32
    • Unscrew the screw in the hole marked by three vertical dots, shown here.
    • The screw is located on the bottom panel of the computer, next to the information panel with the production date.
  2. Sony Vaio VPCEL17FX Disc Drive Replacement: passo 2, imagem 1 %32
    • Pull out the 0.6 mm screw, or rotate the laptop and let it fall out.
    • Be sure to not lose track of this screw, it holds the disc drive in place.
  3. Sony Vaio VPCEL17FX Disc Drive Replacement: passo 3, imagem 1 %32
    • Gently pull the edge of the disc drive until you feel it start to come out. Pull it all the way out, and set it aside.
Conclusão
Nick Sanchez
Membro desde: 09/21/18
97 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 452
