Ir para o conteúdo principal
Sony Vaio VPCEB11FM Keyboard Replacement
O que você precisa
  1. Sony Vaio VPCEB11FM Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Keyboard Replacement: passo 2, imagem 1 %32
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Keyboard Replacement: passo 3, imagem 1 %32
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Keyboard Replacement, DVD Drive: passo 4, imagem 1 %32 Sony Vaio VPCEB11FM Keyboard Replacement, DVD Drive: passo 4, imagem 2 %32
    • Remove the 7mm screws with the Phillips #1 Screwdriver.
  5. Sony Vaio VPCEB11FM Keyboard Replacement: passo 5, imagem 1 %32
    • Grasp the DVD drive's face plate with your fingers and pull out.
  6. Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: passo 6, imagem 1 %32 Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: passo 6, imagem 2 %32 Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: passo 6, imagem 3 %32
    • Within the DVD drive compartment, press on the hole to push the keyboard out of its placement.
    • The keyboard may need to be loosened on its edges with a plastic spudger.
  7. Sony Vaio VPCEB11FM Keyboard Replacement: passo 7, imagem 1 %32 Sony Vaio VPCEB11FM Keyboard Replacement: passo 7, imagem 2 %32 Sony Vaio VPCEB11FM Keyboard Replacement: passo 7, imagem 3 %32
    • Carefully pull the keyboard back to expose ribbon connector.
    • Using a spudger, or your finger tips, carefully slide the the ribbon keeper open.
Conclusão
Uma outra pessoa concluiu este guia.
Maxine Filcher
Membro desde: 01/30/17
1.153 Reputação
Autoria de 8 guias
Equipe
UW Tacoma, Team 1-5, Rose Winter 2017 Membro de UW Tacoma, Team 1-5, Rose Winter 2017
UWT-ROSE-W17S1G5
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 1,973
