Ir para o conteúdo principal
Sony Vaio VPCEB11FM Audio Card Replacement
O que você precisa
  1. Sony Vaio VPCEB11FM Audio Card Replacement, Battery: passo 1, imagem 1 %32
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Audio Card Replacement: passo 2, imagem 1 %32
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Audio Card Replacement: passo 3, imagem 1 %32
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Audio Card Replacement, RAM: passo 4, imagem 1 %32 Sony Vaio VPCEB11FM Audio Card Replacement, RAM: passo 4, imagem 2 %32
    • Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
    • Once the cover has been loosened, pry the cover with your finger for it to come off.
  5. Sony Vaio VPCEB11FM Audio Card Replacement: passo 5, imagem 1 %32 Sony Vaio VPCEB11FM Audio Card Replacement: passo 5, imagem 2 %32 Sony Vaio VPCEB11FM Audio Card Replacement: passo 5, imagem 3 %32
    • Use your fingers to gently pull the white plastic strip outward on both sides.
    • Once you pull the strip, the strip of RAM will loosen up. Once loose the strip of RAM should lift out.
    • Once done with the top strip of RAM continue for all continuous strips.
  6. Sony Vaio VPCEB11FM Audio Card Replacement, Hard Drive: passo 6, imagem 1 %32 Sony Vaio VPCEB11FM Audio Card Replacement, Hard Drive: passo 6, imagem 2 %32
    • Using the Phillips #01 Screwdriver, remove the two 7mm screws.
  7. Sony Vaio VPCEB11FM Audio Card Replacement: passo 7, imagem 1 %32 Sony Vaio VPCEB11FM Audio Card Replacement: passo 7, imagem 2 %32 Sony Vaio VPCEB11FM Audio Card Replacement: passo 7, imagem 3 %32
    • Use your fingers to pry the cover upward.
    • Unscrew the two 7mm screws.
    • Pull the plastic tab in the direction of the arrow to take out.
  8. Sony Vaio VPCEB11FM Audio Card Replacement: passo 8, imagem 1 %32 Sony Vaio VPCEB11FM Audio Card Replacement: passo 8, imagem 2 %32
    • Lift plug side first.
    • Remove all the way.
  9. Sony Vaio VPCEB11FM Audio Card Replacement: passo 9, imagem 1 %32 Sony Vaio VPCEB11FM Audio Card Replacement: passo 9, imagem 2 %32 Sony Vaio VPCEB11FM Audio Card Replacement: passo 9, imagem 3 %32
    • Skip to next step if accessing other components.
    • Remove the 3mm screws with the Phillips #1 Screwdriver from hard drive bracket.
  10. Sony Vaio VPCEB11FM Audio Card Replacement, Audio Card: passo 10, imagem 1 %32 Sony Vaio VPCEB11FM Audio Card Replacement, Audio Card: passo 10, imagem 2 %32 Sony Vaio VPCEB11FM Audio Card Replacement, Audio Card: passo 10, imagem 3 %32
    • #1 Unscrew the back panel
    • #2 Then work the tool around the sides to release cover. You may need a second tool to help keep your loose corner open.
  11. Sony Vaio VPCEB11FM Audio Card Replacement: passo 11, imagem 1 %32 Sony Vaio VPCEB11FM Audio Card Replacement: passo 11, imagem 2 %32 Sony Vaio VPCEB11FM Audio Card Replacement: passo 11, imagem 3 %32
    • Unscrew the screw with the size of * screw driver
    • Left up the case holder
    • Gently pull the connective cable
Conclusão
3 outras pessoas executaram este guia.
Maxine Filcher
Membro desde: 01/30/17
1.135 Reputação
Autoria de 8 guias
Equipe
UW Tacoma, Team 1-5, Rose Winter 2017 Membro de UW Tacoma, Team 1-5, Rose Winter 2017
UWT-ROSE-W17S1G5
Membros da 4
Autoria de 16 guias
Um comentário
I appreciate it
Thedeen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Duração total: 1,077
