Ir para o conteúdo principal
Sony Vaio VPCCW17FX Webcam Replacement
O que você precisa
  1. Sony Vaio VPCCW17FX Webcam Replacement, Webcam: passo 1, imagem 1 %32
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Webcam Replacement: passo 2, imagem 1 %32
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Webcam Replacement: passo 3, imagem 1 %32 Sony Vaio VPCCW17FX Webcam Replacement: passo 3, imagem 2 %32
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Webcam Replacement: passo 4, imagem 1 %32 Sony Vaio VPCCW17FX Webcam Replacement: passo 4, imagem 2 %32
    • Remove the four rubber circles using the spudger located on each corner of the laptop.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver that are located under each rubber circle.
  5. Sony Vaio VPCCW17FX Webcam Replacement: passo 5, imagem 1 %32 Sony Vaio VPCCW17FX Webcam Replacement: passo 5, imagem 2 %32
    • Slowly peel off the plastic covering around the screen.
    • Place it to the side once it is completely disconnected.
    • You may need to apply slight pressure to release the clips of the covering.
  6. Sony Vaio VPCCW17FX Webcam Replacement: passo 6, imagem 1 %32 Sony Vaio VPCCW17FX Webcam Replacement: passo 6, imagem 2 %32 Sony Vaio VPCCW17FX Webcam Replacement: passo 6, imagem 3 %32
    • Remove the two screws (Length: 7.7 mm) using the Phillips #0 screwdriver that hold the Webcam in place.
    • Gently pull the webcam away from the laptop.
    • Slowly disconnect the two ribbon cable connectors by sliding them towards the wire to disconnect the webcam from the laptop.
Conclusão
Tiffani Beck
Membro desde: 03/20/17
219 Reputação
Autoria de 2 guias
Equipe
Texas Tech, Team S8-G5, Bennett Spring 2017 Membro de Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Duração total: 1,106
