Ir para o conteúdo principal
Sony Vaio VPCCW17FX Speakers Replacement
O que você precisa
  1. Sony Vaio VPCCW17FX Speakers Replacement, Speakers: passo 1, imagem 1 %32
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Speakers Replacement: passo 2, imagem 1 %32
    • Slide the two latches towards the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Speakers Replacement: passo 3, imagem 1 %32 Sony Vaio VPCCW17FX Speakers Replacement: passo 3, imagem 2 %32
    • Use fingernail or plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Speakers Replacement: passo 4, imagem 1 %32 Sony Vaio VPCCW17FX Speakers Replacement: passo 4, imagem 2 %32
    • Using a Phillips #0 screwdriver to remove the two screws (Length: 7.7 mm) of the Hard Drive cover and place the cover to the side.
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) from the RAM cover and place it to the side.
  5. Sony Vaio VPCCW17FX Speakers Replacement: passo 5, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove all twelve screws (Length: 7.7 mm) that hold the bottom cover.
  6. Sony Vaio VPCCW17FX Speakers Replacement: passo 6, imagem 1 %32
    • Lift and remove the back cover.
  7. Sony Vaio VPCCW17FX Speakers Replacement: passo 7, imagem 1 %32 Sony Vaio VPCCW17FX Speakers Replacement: passo 7, imagem 2 %32
    • Locate the fan and use a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold it in place.
    • Lift the fan and move it out of the way.
  8. Sony Vaio VPCCW17FX Speakers Replacement: passo 8, imagem 1 %32 Sony Vaio VPCCW17FX Speakers Replacement: passo 8, imagem 2 %32
    • Begin removing the four screws with a Phillips #0 screwdriver (Length: 7.7 mm) from the back cover.
    • Place the cover out of the way.
    • Be careful to not pull any wires out while moving the cover.
  9. Sony Vaio VPCCW17FX Speakers Replacement: passo 9, imagem 1 %32 Sony Vaio VPCCW17FX Speakers Replacement: passo 9, imagem 2 %32 Sony Vaio VPCCW17FX Speakers Replacement: passo 9, imagem 3 %32
    • Using a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold the speaker in place.
    • Follow the wire until you find the ribbon cable that holds the wires and pull straight out of the connect to remove it.
    • You are now free to replace the speakers.
    • There are two speakers so be sure to repeat the same steps for the second speaker.
Conclusão
Brianna Rukes
Membro desde: 03/21/17
101 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team S8-G5, Bennett Spring 2017 Membro de Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 479
