Ir para o conteúdo principal
Sony Vaio VPCCW17FX LCD Screen Replacement
O que você precisa
  1. Sony Vaio VPCCW17FX LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX LCD Screen Replacement: passo 2, imagem 1 %32
    • Slide both latches towards the center of the battery to release.
  3. Sony Vaio VPCCW17FX LCD Screen Replacement: passo 3, imagem 1 %32 Sony Vaio VPCCW17FX LCD Screen Replacement: passo 3, imagem 2 %32
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX LCD Screen Replacement: passo 4, imagem 1 %32 Sony Vaio VPCCW17FX LCD Screen Replacement: passo 4, imagem 2 %32
    • Remove the rubber pads on all four corners of the screen bezel using the spudger.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver.
  5. Sony Vaio VPCCW17FX LCD Screen Replacement: passo 5, imagem 1 %32
    • Remove the screen's plastic bezel.
    • You need to use slight pressure to release the clips.
  6. Sony Vaio VPCCW17FX LCD Screen Replacement: passo 6, imagem 1 %32 Sony Vaio VPCCW17FX LCD Screen Replacement: passo 6, imagem 2 %32
    • Remove all four screws (Length: 7.7 mm) using a Phillips #0 screwdriver. Make sure to hold the screen while removing the screws so it doesn't fall.
    • Using your thumb, carefully lower the glass and place it on the keyboard.
    • Do this slowly to avoid damaging the screen.
  7. Sony Vaio VPCCW17FX LCD Screen Replacement: passo 7, imagem 1 %32 Sony Vaio VPCCW17FX LCD Screen Replacement: passo 7, imagem 2 %32
    • Pull off the tape and disconnect the display cable connector by gently sliding up to remove it from its socket.
  8. Sony Vaio VPCCW17FX LCD Screen Replacement: passo 8, imagem 1 %32
    • The screen can now be removed.
Conclusão
Uma outra pessoa concluiu este guia.
Seowon Song
Membro desde: 03/20/17
113 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team S8-G5, Bennett Spring 2017 Membro de Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 1,096
