Ir para o conteúdo principal
Sony Vaio VPCCW17FX Hard Drive Replacement
O que você precisa
  1. Sony Vaio VPCCW17FX Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide the two latches towards the center of the battery to release it.
  3. Sony Vaio VPCCW17FX Hard Drive Replacement: passo 3, imagem 1 %32 Sony Vaio VPCCW17FX Hard Drive Replacement: passo 3, imagem 2 %32
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Hard Drive Replacement: passo 4, imagem 1 %32 Sony Vaio VPCCW17FX Hard Drive Replacement: passo 4, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the two 7.7 mm screws from the hard drive cover and place it to the side.
  5. Sony Vaio VPCCW17FX Hard Drive Replacement: passo 5, imagem 1 %32 Sony Vaio VPCCW17FX Hard Drive Replacement: passo 5, imagem 2 %32 Sony Vaio VPCCW17FX Hard Drive Replacement: passo 5, imagem 3 %32
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that hold the hard drive in place.
    • Use the tab to slide the hard drive away from the laptop.
    • Set the disconnected hard drive away from the laptop.
  6. Sony Vaio VPCCW17FX Hard Drive Replacement: passo 6, imagem 1 %32 Sony Vaio VPCCW17FX Hard Drive Replacement: passo 6, imagem 2 %32 Sony Vaio VPCCW17FX Hard Drive Replacement: passo 6, imagem 3 %32
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that cover the hard drive.
    • Use the tab to pull up on the metal cover and remove it.
    • You are now free to replace the hard drive.
Conclusão
Tiffani Beck
Membro desde: 03/20/17
219 Reputação
Autoria de 2 guias
Equipe
Texas Tech, Team S8-G5, Bennett Spring 2017 Membro de Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 1,619
