Ir para o conteúdo principal
Sony Vaio VPC-Y2190X Hard Drive Replacement
O que você precisa
  1. Sony Vaio VPC-Y2190X Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Flip your laptop so that the bottom is facing up.
  2. Sony Vaio VPC-Y2190X Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide the “Lock” switch to the right.
    • Slide and hold the “Release” switch to the left.
  3. Sony Vaio VPC-Y2190X Hard Drive Replacement: passo 3, imagem 1 %32 Sony Vaio VPC-Y2190X Hard Drive Replacement: passo 3, imagem 2 %32
    • While holding the “Release” switch, lift the lip of the battery.
    • Lift the battery up and out of the laptop.
  4. Sony Vaio VPC-Y2190X Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Using a #0PH screwdriver, unscrew the three 4.80mm screws on the back of the device.
    • The screws are held into the panel by washers, they will not fall out once unscrewed.
  5. Sony Vaio VPC-Y2190X Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the panel.
    • Use the #0PH screwdriver to remove the four 3.61mm screws.
  6. Sony Vaio VPC-Y2190X Hard Drive Replacement: passo 6, imagem 1 %32 Sony Vaio VPC-Y2190X Hard Drive Replacement: passo 6, imagem 2 %32
    • Carefully lift the hard drive.
    • Remove the hard drive by pulling it to the left.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 349
