Ir para o conteúdo principal
Sony Vaio VGN-SR140E Screen Replacement
O que você precisa
  1. Sony Vaio VGN-SR140E Screen Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Screen Replacement: passo 2, imagem 1 %32
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Screen Replacement: passo 3, imagem 1 %32 Sony Vaio VGN-SR140E Screen Replacement: passo 3, imagem 2 %32
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Screen Replacement, Screen: passo 4, imagem 1 %32 Sony Vaio VGN-SR140E Screen Replacement, Screen: passo 4, imagem 2 %32 Sony Vaio VGN-SR140E Screen Replacement, Screen: passo 4, imagem 3 %32
    • Remove the rubber pads at all four corners of the screen bezel using a spudger. This will reveal four 5mm Phillips screws.
    • Use a Phillips #1 screwdriver to remove the four screws and set them aside.
  5. Sony Vaio VGN-SR140E Screen Replacement: passo 5, imagem 1 %32
    • Remove the screen's plastic bezel. You may need to use slight pressure to release the clips that secure the bezel to the laptop.
  6. Sony Vaio VGN-SR140E Screen Replacement: passo 6, imagem 1 %32 Sony Vaio VGN-SR140E Screen Replacement: passo 6, imagem 2 %32
    • Lift screen bezel up and off of the laptop.
  7. Sony Vaio VGN-SR140E Screen Replacement: passo 7, imagem 1 %32 Sony Vaio VGN-SR140E Screen Replacement: passo 7, imagem 2 %32 Sony Vaio VGN-SR140E Screen Replacement: passo 7, imagem 3 %32
    • Close the laptop carefully and slowly while holding the screen with your thumb to prevent it from falling.
    • Lay the screen gently on the keyboard. This will reveal the screen's connector.
  8. Sony Vaio VGN-SR140E Screen Replacement: passo 8, imagem 1 %32 Sony Vaio VGN-SR140E Screen Replacement: passo 8, imagem 2 %32 Sony Vaio VGN-SR140E Screen Replacement: passo 8, imagem 3 %32
    • Grasp the connector and gently pull it out.
  9. Sony Vaio VGN-SR140E Screen Replacement: passo 9, imagem 1 %32
    • The screen can now be removed.
Conclusão
Jeremy
Membro desde: 03/18/15
722 Reputação
Autoria de 4 guias
Equipe
Michigan Tech, Team 1-6, Lauer Spring 2015 Membro de Michigan Tech, Team 1-6, Lauer Spring 2015
MTU-LAUER-S15S1G6
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 1,140
