Ir para o conteúdo principal
Sony Vaio VGN-S260 Keyboard Replacement
O que você precisa
  1. Sony Vaio VGN-S260 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio VGN-S260 Keyboard Replacement, Battery: passo 1, imagem 2 %32 Sony Vaio VGN-S260 Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Keyboard Replacement: passo 2, imagem 1 %32 Sony Vaio VGN-S260 Keyboard Replacement: passo 2, imagem 2 %32
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Sony Vaio VGN-S260 Keyboard Replacement, Keyboard: passo 3, imagem 2 %32
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Keyboard Replacement: passo 4, imagem 1 %32
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Keyboard Replacement: passo 5, imagem 1 %32 Sony Vaio VGN-S260 Keyboard Replacement: passo 5, imagem 2 %32
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Keyboard Replacement: passo 6, imagem 1 %32 Sony Vaio VGN-S260 Keyboard Replacement: passo 6, imagem 2 %32
    • Lift up lever underneath the ribbon to detach the keyboard.
Conclusão
Uma outra pessoa concluiu este guia.
Jeffrey Bryan
Membro desde: 04/20/10
570 Reputação
Autoria de 11 guias
Equipe
Cal Poly, Team 16-4, Maness Spring 2010 Membro de Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
Membros da 4
Autoria de 30 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 5,459
