Ir para o conteúdo principal
Sony Vaio VGN-S260 Fan Replacement
O que você precisa
  1. Sony Vaio VGN-S260 Fan Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement, Battery: passo 1, imagem 2 %32 Sony Vaio VGN-S260 Fan Replacement, Battery: passo 1, imagem 3 %32
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Fan Replacement: passo 2, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement: passo 2, imagem 2 %32
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Fan Replacement, Keyboard: passo 3, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement, Keyboard: passo 3, imagem 2 %32
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Fan Replacement: passo 4, imagem 1 %32
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Fan Replacement: passo 5, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement: passo 5, imagem 2 %32
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Fan Replacement: passo 6, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement: passo 6, imagem 2 %32
    • Lift up lever underneath the ribbon to detach the keyboard.
  7. Sony Vaio VGN-S260 Fan Replacement, Upper Casing: passo 7, imagem 1 %32
    • Remove memory/wireless compartment cover.
  8. Sony Vaio VGN-S260 Fan Replacement: passo 8, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement: passo 8, imagem 2 %32 Sony Vaio VGN-S260 Fan Replacement: passo 8, imagem 3 %32
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  9. Sony Vaio VGN-S260 Fan Replacement: passo 9, imagem 1 %32
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  10. Sony Vaio VGN-S260 Fan Replacement: passo 10, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement: passo 10, imagem 2 %32 Sony Vaio VGN-S260 Fan Replacement: passo 10, imagem 3 %32
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  11. Sony Vaio VGN-S260 Fan Replacement: passo 11, imagem 1 %32
    • Remove the upper casing.
  12. Sony Vaio VGN-S260 Fan Replacement, Optical Drive: passo 12, imagem 1 %32
    • Remove the screw holding the optical drive casing to the logic board.
  13. Sony Vaio VGN-S260 Fan Replacement: passo 13, imagem 1 %32
    • Locate ribbon connecting optical drive case to logic board.
    • Pop off the ribbon.
    • Remove the metal PC-Card cage.
  14. Sony Vaio VGN-S260 Fan Replacement: passo 14, imagem 1 %32
    • Remove the four screws holding the optical drive to the logic board.
  15. Sony Vaio VGN-S260 Fan Replacement: passo 15, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement: passo 15, imagem 2 %32
    • Locate brown locking tab above optical drive.
    • Lift up on brown locking tab until ribbon is loose.
    • Gently slide out and remove the optical drive from the computer.
  16. Sony Vaio VGN-S260 Fan Replacement, Ethernet Ports: passo 16, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement, Ethernet Ports: passo 16, imagem 2 %32
    • Remove the blue ribbon from the Ethernet Circuit Board.
  17. Sony Vaio VGN-S260 Fan Replacement: passo 17, imagem 1 %32
    • Remove the screws near the Ethernet Port circuit board.
  18. Sony Vaio VGN-S260 Fan Replacement: passo 18, imagem 1 %32
    • Remove the screws for the second ethernet circuit board.
  19. Sony Vaio VGN-S260 Fan Replacement: passo 19, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement: passo 19, imagem 2 %32
    • Remove the ethernet ports.
  20. Sony Vaio VGN-S260 Fan Replacement, Hard Drive: passo 20, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement, Hard Drive: passo 20, imagem 2 %32
    • Remove the screws holding the hard drive casing in place.
  21. Sony Vaio VGN-S260 Fan Replacement: passo 21, imagem 1 %32
    • Find orange ribbon that is connected to the hard drive.
    • Find the holder of the ribbon and pop the ribbon off from it.
  22. Sony Vaio VGN-S260 Fan Replacement: passo 22, imagem 1 %32
    • Remove the casing and the orange ribbon.
  23. Sony Vaio VGN-S260 Fan Replacement, Power Adapter: passo 23, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement, Power Adapter: passo 23, imagem 2 %32
    • Locate the yellow power adapter.
    • Follow its wire to white logic board connector.
    • Pull out the wire from white logic board connector.
  24. Sony Vaio VGN-S260 Fan Replacement: passo 24, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement: passo 24, imagem 2 %32 Sony Vaio VGN-S260 Fan Replacement: passo 24, imagem 3 %32
    • Locate the screws on the fan filter casing.
    • Remove these screws.
  25. Sony Vaio VGN-S260 Fan Replacement: passo 25, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement: passo 25, imagem 2 %32
    • Remove the screw next to the yellow power adapter.
    • Lift out power adapter and fan filter.
  26. Sony Vaio VGN-S260 Fan Replacement, Motherboard: passo 26, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement, Motherboard: passo 26, imagem 2 %32
    • Remove screws on the motherboard.
  27. Sony Vaio VGN-S260 Fan Replacement: passo 27, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement: passo 27, imagem 2 %32
    • Remove the nut using a 5mm nut driver.
    • Using a magnetic screwdriver handle will also work as well.
  28. Sony Vaio VGN-S260 Fan Replacement: passo 28, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement: passo 28, imagem 2 %32
    • Remove the LCD display ribbon with a nylon spudger.
    • This is difficult to remove.
  29. Sony Vaio VGN-S260 Fan Replacement: passo 29, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement: passo 29, imagem 2 %32 Sony Vaio VGN-S260 Fan Replacement: passo 29, imagem 3 %32
    • Gently lift the motherboard from the laptop.
    • The motherboard will be attached to the network wireless chip, which is also attached to the base of the laptop.
    • Remove the chip by popping the tabs on the side.
    • Slide out the network card.
    • You are now free to take the motherboard away from the base.
  30. Sony Vaio VGN-S260 Fan Replacement, Fan: passo 30, imagem 1 %32
    • Disconnect the fan wire from the logic board
  31. Sony Vaio VGN-S260 Fan Replacement: passo 31, imagem 1 %32 Sony Vaio VGN-S260 Fan Replacement: passo 31, imagem 2 %32
    • Turn the logic board over and Locate the screws connecting the fan to the logic board
    • Gently remove the fan from the logic board
Conclusão
Jeffrey Bryan
Membro desde: 04/20/10
570 Reputação
Autoria de 11 guias
Equipe
Cal Poly, Team 16-4, Maness Spring 2010 Membro de Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
Membros da 4
Autoria de 30 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 17
Duração total: 8,350
