Ir para o conteúdo principal
Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement
O que você precisa
  1. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Power off the laptop.
    • Unplug the charging cable and any other cables plugged into the laptop.
    • Failure to remove or unplug any cables could result in electric shock.
    • Turn the laptop over so that the back panel is facing upwards.
  2. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 2, imagem 1 %32
    • Locate two switches above the battery that lock it into place.
    • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
  3. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 3, imagem 1 %32
    • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
  4. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement, Back Panel: passo 4, imagem 1 %32 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement, Back Panel: passo 4, imagem 2 %32 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement, Back Panel: passo 4, imagem 3 %32
    • Remove all the 8mm Phillips #1 screws on the backside of the laptop.
    • There are three 3mm and two 5.3mm screws under the battery that also need to be taken out.
    • There are three 3mm screws under the optical drives that also need to be taken out.
    • Remove the RAM panel in addition to the other screws. For further instructions, refer to the RAM replacement guide.
  5. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 5, imagem 1 %32 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 5, imagem 2 %32 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 5, imagem 3 %32
    • Pry along the edges of the back panel using the spudger.
    • If you are struggling to remove the back panel with a moderate amount of force, do NOT apply any additional force, instead double check to make sure all the screws were removed before attempting again.
  6. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement, Fan: passo 6, imagem 1 %32
    • Locate and remove three 5.3 mm Phillips #1 screws on the bottom of the fan.
    • Locate and remove the four 5.3 mm Phillips #1 screws on the top of the fan.
  7. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 7, imagem 1 %32
    • Locate and remove the four 3mm Phillips #1 screws above the processor and attached to the bronze heat-pipes.
    • Gently lift up the fan and heatsink from the the laptop.
    • If the fan and heatsink will not lift up with ease, do NOT apply any additional force. Check again to see if all necessary screws are removed.
  8. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 8, imagem 1 %32
    • The fan attached onto the heat sink with electrical tape. Removing the electrical tape allows you to replace the fan.
  9. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement, Keyboard: passo 9, imagem 1 %32
    • Locate the two highlighted circular openings and push the keyboard out.
    • There is a ribbon cable attaching the keyboard to the back of the motherboard. Avoid damaging the ribbon when pushing out the keyboard.
  10. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 10, imagem 1 %32
    • Detach the ribbon cable to separate the keyboard from the laptop.
    • Push open the brown clamp at the base of the ribbon to release it.
  11. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement, Motherboard: passo 11, imagem 1 %32
    • Remove the highlighted ribbon cables from their place underneath the keyboard. To do so, lift up on the black clamps to release the cables.
  12. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 12, imagem 1 %32 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 12, imagem 2 %32
    • Remove the highlighted 3mm Phillips #1 screws.
    • Remove the two 8mm Phillips #1 screws that are highlighted.
  13. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 13, imagem 1 %32 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 13, imagem 2 %32 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 13, imagem 3 %32
    • Detach all of the highlighted connectors.
    • If the connector has a plastic cable, use it to assist in removal.
    • Detach the black and grey network card cables.
  14. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 14, imagem 1 %32 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: passo 14, imagem 2 %32
    • Carefully lift up the motherboard from its place.
    • The USB input/output area sits within the back plate of the laptop. To ensure safe removal, lift up and pull away from the USB input panel.
    • If the motherboard does lift up or come out easily, do not apply any additional force. Check again for any unattached cables or connects before attempting again.
Conclusão
6 outras pessoas executaram este guia.
Kevin McGowan
Membro desde: 04/22/14
619 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 9-17, Regan Spring 2014 Membro de Cal Poly, Team 9-17, Regan Spring 2014
CPSU-REGAN-S14S9G17
Membros da 4
Autoria de 18 guias
Um comentário
Excellent instructions and pics. Thank you for this guide!
stbza - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 33
Duração total: 11,006
