Ir para o conteúdo principal
Sony Vaio VGN-FS640 Fan Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Sony Vaio VGN-FS640 Fan Replacement, Backplate: passo 1, imagem 1 %32
    • Turn off the laptop and disconnect any charging cables.
    • Flip the laptop over so that the Service Tag is shown at the top left corner.
  2. Sony Vaio VGN-FS640 Fan Replacement: passo 2, imagem 1 %32
    • Remove the highlighted screws from the back of the laptop with a Phillips #0 Screwdriver.
  3. Sony Vaio VGN-FS640 Fan Replacement: passo 3, imagem 1 %32
    • Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
  4. Sony Vaio VGN-FS640 Fan Replacement: passo 4, imagem 1 %32
    • Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
  5. Sony Vaio VGN-FS640 Fan Replacement: passo 5, imagem 1 %32
    • Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
  6. Sony Vaio VGN-FS640 Fan Replacement: passo 6, imagem 1 %32
    • Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
  7. Sony Vaio VGN-FS640 Fan Replacement: passo 7, imagem 1 %32
    • Locate the battery, located on the top side of the laptop to the right of the Service Tag .
    • Remove the battery by pressing inwards on the tabs on either side of the battery.
  8. Sony Vaio VGN-FS640 Fan Replacement: passo 8, imagem 1 %32
    • Remove cover in the top left side of the laptop next to the battery by pulling it outwards.
  9. Sony Vaio VGN-FS640 Fan Replacement: passo 9, imagem 1 %32
    • Remove the backplate of the laptop by pulling it away from the laptop.
  10. Sony Vaio VGN-FS640 Fan Replacement, Fan: passo 10, imagem 1 %32 Sony Vaio VGN-FS640 Fan Replacement, Fan: passo 10, imagem 2 %32 Sony Vaio VGN-FS640 Fan Replacement, Fan: passo 10, imagem 3 %32
    • Gently remove the connector for the wire running over the fan by lifting the tab on top up with your fingernail and sliding it out.
  11. Sony Vaio VGN-FS640 Fan Replacement: passo 11, imagem 1 %32 Sony Vaio VGN-FS640 Fan Replacement: passo 11, imagem 2 %32
    • Remove the four screws securing the fan.
  12. Sony Vaio VGN-FS640 Fan Replacement: passo 12, imagem 1 %32 Sony Vaio VGN-FS640 Fan Replacement: passo 12, imagem 2 %32
    • Gently lift out the fan.
    • Do not forcefully pull the fan away. This may damage the circuit board.
  13. Sony Vaio VGN-FS640 Fan Replacement: passo 13, imagem 1 %32 Sony Vaio VGN-FS640 Fan Replacement: passo 13, imagem 2 %32
    • Gently disconnect the remaining wire connecting the fan to the circuit board.
    • Remove the fan from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Geoffrey
Membro desde: 03/28/14
252 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-6, Vijaybhaskar Spring 2014 Membro de UMass Dartmouth, Team 2-6, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S2G6
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 14
Duração total: 546
