Introdução
Use this guide to replace the speakers on a Sony Vaio Tap 21 all-in-one desktop. There are two speakers which are located on the upper corners of the device. They are connected to each other with a red and black cable.
O que você precisa
Insert the plastic opening tool at an angle into the grill and lift the tab by applying force down and to the left as you are lifting it out of place.
Use your plastic opening tool to remove the right plastic tab blocking the screw mounts behind the device.
The plastic tab is located on a plastic stretch of grill running along the upper half of the back of the device.
Remove four 9mm screws from the fan attachment located on the motherboard with a Phillips #1 screwdriver.
Use a JIS 00 screwdriver to remove a 5mm screw from the wireless receiver.
