O que você precisa
Begin by opening the HDMI/USB port cover on the left edge.
Remove the three #000 headed, 3 mm long screws located underneath the port cover.
Begin by removing the orange ribbon cable connecting the motherboard to the daughterboard, located above the SSD.
Gently tug either side until it releases, then pull out the other end.
