Ir para o conteúdo principal
Sony Vaio Tap 11 Solid State Disk Replacement
O que você precisa
  1. Sony Vaio Tap 11 Solid State Disk Replacement, Screen Assembly: passo 1, imagem 1 %32
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Solid State Disk Replacement: passo 2, imagem 1 %32
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Solid State Disk Replacement: passo 3, imagem 1 %32 Sony Vaio Tap 11 Solid State Disk Replacement: passo 3, imagem 2 %32
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Solid State Disk Replacement, Solid State Disk: passo 4, imagem 1 %32
    • Unplug the battery connector located beside the fan.
    • Locate the SSD on the right side of the device, above the battery and beneath the WiFi chip.
  5. Sony Vaio Tap 11 Solid State Disk Replacement: passo 5, imagem 1 %32
    • Remove the two 3 mm Phillips #000 screws from the right edge of the SSD.
  6. Sony Vaio Tap 11 Solid State Disk Replacement: passo 6, imagem 1 %32 Sony Vaio Tap 11 Solid State Disk Replacement: passo 6, imagem 2 %32
    • Pull the SSD towards the right and slightly up, removing it from the back assembly.
Conclusão
3 outras pessoas executaram este guia.
Alexander Bridges
Membro desde: 09/16/15
1.217 Reputação
Autoria de 7 guias
Equipe
IUPUI, Team 1-2, Harley Fall 2015 Membro de IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
Membros da 4
Autoria de 20 guias
3 comentários
What kind of M2 Type? SSD is needed for replacement/upgrade?
Marius - Responder
OK, found the answer, it's mSATA, like the Samsung 840 EVO Series:
http://www.samsung.com/us/business/suppo...
Marius -
I did the same without pulling out the battery jack. As i tried to turn the tablet on it didn’t work. Even the fan stopped working. I inserted the power cable but no response .. nothing at all ! Please help!
ib_1990_ib - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 47
Duração total: 6,006
