Ir para o conteúdo principal
Sony Vaio Tap 11 Power Jack Replacement
O que você precisa
  1. Sony Vaio Tap 11 Power Jack Replacement, Screen Assembly: passo 1, imagem 1 %32
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Power Jack Replacement: passo 2, imagem 1 %32
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Power Jack Replacement: passo 3, imagem 1 %32 Sony Vaio Tap 11 Power Jack Replacement: passo 3, imagem 2 %32
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Power Jack Replacement, Battery: passo 4, imagem 1 %32
    • Disconnect the battery from the motherboard by pulling out the cable below the fan.
  5. Sony Vaio Tap 11 Power Jack Replacement: passo 5, imagem 1 %32
    • Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
    • Carefully remove the battery from the back assembly.
  6. Sony Vaio Tap 11 Power Jack Replacement, Power Jack: passo 6, imagem 1 %32
    • Remove the two 3mm Phillips #000 screws from the bottom left corner of the device.
  7. Sony Vaio Tap 11 Power Jack Replacement: passo 7, imagem 1 %32
    • Unplug the jack from the motherboard.
  8. Sony Vaio Tap 11 Power Jack Replacement: passo 8, imagem 1 %32
    • Remove the metal covering.
  9. Sony Vaio Tap 11 Power Jack Replacement: passo 9, imagem 1 %32
    • Pull out the cable and jack assembly.
Conclusão
3 outras pessoas executaram este guia.
Alexander Bridges
Membro desde: 09/16/15
1.217 Reputação
Autoria de 7 guias
Equipe
IUPUI, Team 1-2, Harley Fall 2015 Membro de IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
Membros da 4
Autoria de 20 guias
2 comentários
I wonder if you have the part number or can supply this power jack?
James Toal - Responder
Yes, Where can I find this replacement part?
mikebeard65 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Duração total: 1,780
