Introdução
The USB Port and Board are used to read data from a USB so that data can be transferred to and from it allowing for the portable storage and transfer of data.
O que você precisa
Flip the laptop over so that the battery on the underside of the device is revealed.
Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
Unscrew the three 4mm screws using a JIS #0 screwdriver.
Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
Grab and lift the edge of the panel to pull it free from the rest of the computer.
Use a JIS #0 screwdriver to unscrew the two 4mm screws from the board.
