Ir para o conteúdo principal
Sony Vaio SVT151A11L Multimedia Card Replacement
O que você precisa
  1. Sony Vaio SVT151A11L Multimedia Card Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio SVT151A11L Multimedia Card Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L Multimedia Card Replacement: passo 2, imagem 1 %32 Sony Vaio SVT151A11L Multimedia Card Replacement: passo 2, imagem 2 %32 Sony Vaio SVT151A11L Multimedia Card Replacement: passo 2, imagem 3 %32
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
  3. Sony Vaio SVT151A11L Multimedia Card Replacement, Back Panel: passo 3, imagem 1 %32 Sony Vaio SVT151A11L Multimedia Card Replacement, Back Panel: passo 3, imagem 2 %32 Sony Vaio SVT151A11L Multimedia Card Replacement, Back Panel: passo 3, imagem 3 %32
    • Unscrew the three 4mm screws using a JIS #0 screwdriver.
    • Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
    • Grab and lift the edge of the panel to pull it free from the rest of the computer.
  4. Sony Vaio SVT151A11L Multimedia Card Replacement: passo 4, imagem 1 %32 Sony Vaio SVT151A11L Multimedia Card Replacement: passo 4, imagem 2 %32 Sony Vaio SVT151A11L Multimedia Card Replacement: passo 4, imagem 3 %32
    • Grab the disk drive located at the edge of the computer and pull it it out.
    • Unscrew the three 7 mm screws with a JIS #0 screwdriver.
  5. Sony Vaio SVT151A11L Multimedia Card Replacement, Multimedia Card: passo 5, imagem 1 %32
    • Get unobstructed access to the multimedia card.
  6. Sony Vaio SVT151A11L Multimedia Card Replacement: passo 6, imagem 1 %32 Sony Vaio SVT151A11L Multimedia Card Replacement: passo 6, imagem 2 %32
    • Unscrew the two 2mm screws from the board using JIS #0 screwdriver.
  7. Sony Vaio SVT151A11L Multimedia Card Replacement: passo 7, imagem 1 %32 Sony Vaio SVT151A11L Multimedia Card Replacement: passo 7, imagem 2 %32
    • Lift up multimedia card.
    • Pull out ribbon cable from connected board.
Conclusão
Equipe
UMass Dartmouth, Team S4-G6, Julie Fall 2017 Membro de UMass Dartmouth, Team S4-G6, Julie Fall 2017
UMASSD-JULIE-F17S4G6
Membros da 2
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 653
