Ir para o conteúdo principal
Sony Vaio SVT151A11L Battery Replacement
O que você precisa
  1. Sony Vaio SVT151A11L Battery Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio SVT151A11L Battery Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L Battery Replacement: passo 2, imagem 1 %32 Sony Vaio SVT151A11L Battery Replacement: passo 2, imagem 2 %32 Sony Vaio SVT151A11L Battery Replacement: passo 2, imagem 3 %32
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
Conclusão
3 outras pessoas executaram este guia.
Nathan McGarvey
Membro desde: 10/20/17
481 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S4-G6, Julie Fall 2017 Membro de UMass Dartmouth, Team S4-G6, Julie Fall 2017
UMASSD-JULIE-F17S4G6
Membros da 2
Autoria de 12 guias
4 comentários
Just got the new Sony Vaio SVT151A11L Battery VGP-BPS33 Li-ion, 11.4V, 3760mAh, 43W,Silver , looks in good condition and similar as original. fix it in laptop and works well up to now. one more thing, it costs less than my thought.
julie - Responder
what size screws and thread type are used for battery mount. i have lost mine
John Sears - Responder
My computer battery is not contacted what i can do for this problem
Matiullah - Responder
SVT151A11L
SVT15112CXS
Laptop computer
Battery not connected
What i can do
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 40
Duração total: 3,371
