Ir para o conteúdo principal
Sony Vaio SVT131A11L Hard Drive Replacement
O que você precisa
  1. Sony Vaio SVT131A11L Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio SVT131A11L Hard Drive Replacement, Battery: passo 1, imagem 2 %32 Sony Vaio SVT131A11L Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Carefully grab the edges of the laptop and flip it over to reveal the back panel.
    • The battery is located on the lower half of the back panel, and contains three 10mm flat-head screws.
    • Unscrew the three 10mm flat-head screws using a flat-head screw driver.
    • Lift the battery from the lip closest to the middle screw to remove the battery entirely.
  2. Sony Vaio SVT131A11L Hard Drive Replacement, Hard Drive: passo 2, imagem 1 %32
    • The Hard Drive bay cover has three Phillips head screws at two different lengths. Be sure to organize your screws, as improper replacement will result in damage to your device.
    • The middle Phillips head screw is 10mm in length and will only fit in this thread. Unscrew the 10mm Phillips head screw and keep it separate from the other two screws in this step.
    • Unscrew the two remaining 5mm Phillips head screws on the left and right side of the hard drive bay cover.
    • Lift the panel to remove it.
  3. Sony Vaio SVT131A11L Hard Drive Replacement: passo 3, imagem 1 %32 Sony Vaio SVT131A11L Hard Drive Replacement: passo 3, imagem 2 %32
    • Remove the three 5mm Phillips head screws that secure the Hard Drive bay to the back panel.
  4. Sony Vaio SVT131A11L Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the Hard Drive bay by gently pulling the black plastic tab away from the SATA connector.
    • When removing the hard drive bay, it is important not to pull the black tab too hard, it may rip off/cause damage to the SATA connector, resulting in much bigger issues.
    • Using a plastic pry-tool to push the drive away from the SATA connector can also help at this step.
  5. Sony Vaio SVT131A11L Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the two 5mm Phillips head screws on either side of the Hard Drive bay. There are four screws total in this step.
  6. Sony Vaio SVT131A11L Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove your damaged hard drive and insert the new hard drive into the enclosure.
    • Use the same four 5mm Phillips head screws to attach the drive to the enclosure.
Conclusão
3 outras pessoas executaram este guia.
Benjamin
Membro desde: 10/18/17
651 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S4-G5, Julie Fall 2017 Membro de UMass Dartmouth, Team S4-G5, Julie Fall 2017
UMASSD-JULIE-F17S4G5
Membros da 3
Autoria de 10 guias
2 comentários
I would like to know if you sell the adapter for the hard drive because I have this laptop and all I need is the hard drive adapter to connect a hard drive if you could email me at stephenwrayexley@gmail.com I would greatly appreciate that
Stephen Exley - Responder
bom dia, tem algum video mostrando como instalar o widnows 10 nesse vaio sendo que o mesmo esta com W7? Não consegui entender a BIOS com RAID etc. grato
Valmir Nemer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 48
Duração total: 8,647
