Ir para o conteúdo principal
Sony Vaio SVF15A16CXB RAM Replacement
O que você precisa
  1. Sony Vaio SVF15A16CXB RAM Replacement, Back Panel: passo 1, imagem 1 %32
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15A16CXB RAM Replacement: passo 2, imagem 1 %32 Sony Vaio SVF15A16CXB RAM Replacement: passo 2, imagem 2 %32
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15A16CXB RAM Replacement: passo 3, imagem 1 %32
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15A16CXB RAM Replacement: passo 4, imagem 1 %32
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
  5. Sony Vaio SVF15A16CXB RAM Replacement, RAM: passo 5, imagem 1 %32
    • Locate the two metal clips securing the RAM.
  6. Sony Vaio SVF15A16CXB RAM Replacement: passo 6, imagem 1 %32
    • Pull apart the two metal clips with your fingers.
    • Once you pull the metal clips away, the RAM will spring up from its original position.
  7. Sony Vaio SVF15A16CXB RAM Replacement: passo 7, imagem 1 %32
    • Pull the RAM out of the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 682
