Ir para o conteúdo principal
Sony Vaio SVF15A16CXB Fan Replacement
O que você precisa
  1. Sony Vaio SVF15A16CXB Fan  Replacement, Back Panel: passo 1, imagem 1 %32
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15A16CXB Fan  Replacement: passo 2, imagem 1 %32 Sony Vaio SVF15A16CXB Fan  Replacement: passo 2, imagem 2 %32
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15A16CXB Fan  Replacement: passo 3, imagem 1 %32
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15A16CXB Fan  Replacement: passo 4, imagem 1 %32
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
  5. Sony Vaio SVF15A16CXB Fan  Replacement, Fan: passo 5, imagem 1 %32
    • Unplug the clip (red black yellow wires) by pulling it in an upward direction.
  6. Sony Vaio SVF15A16CXB Fan  Replacement: passo 6, imagem 1 %32
    • Remove two 4mm screws on the left side of the circular fan.
    • Both of these screws have a white washer attached.
  7. Sony Vaio SVF15A16CXB Fan  Replacement: passo 7, imagem 1 %32
    • Unscrew the four 4mm screws from the connecting copper piece. The two screws are located on either side of the copper piece.
    • The 4 mm screws won’t come out but the fan will, the screws are just to hold the fan in place.
  8. Sony Vaio SVF15A16CXB Fan  Replacement: passo 8, imagem 1 %32 Sony Vaio SVF15A16CXB Fan  Replacement: passo 8, imagem 2 %32
    • Gently pull off the fan from the motherboard.
Conclusão
qiuhong Li
Membro desde: 10/04/18
109 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 526
