Ir para o conteúdo principal
Sony Vaio SVF15A16CXB Back Panel Replacement
O que você precisa
  1. Sony Vaio SVF15A16CXB Back Panel  Replacement, Back Panel: passo 1, imagem 1 %32
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15A16CXB Back Panel  Replacement: passo 2, imagem 1 %32 Sony Vaio SVF15A16CXB Back Panel  Replacement: passo 2, imagem 2 %32
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15A16CXB Back Panel  Replacement: passo 3, imagem 1 %32
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15A16CXB Back Panel  Replacement: passo 4, imagem 1 %32
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 16
Duração total: 995
