Ir para o conteúdo principal
Sony Vaio SVE171C11L RAM Replacement
O que você precisa
  1. Sony Vaio SVE171C11L RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE171C11L RAM Replacement: passo 2, imagem 1 %32
    • Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
    • Use your left hand to push up the left tab to release the battery.
  3. Sony Vaio SVE171C11L RAM Replacement: passo 3, imagem 1 %32
    • After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
  4. Sony Vaio SVE171C11L RAM Replacement: passo 4, imagem 1 %32
    • Pull the battery away.
  5. Sony Vaio SVE171C11L RAM Replacement, RAM: passo 5, imagem 1 %32
    • Unscrew the single 3mm screw to remove the RAM panel.
  6. Sony Vaio SVE171C11L RAM Replacement: passo 6, imagem 1 %32
    • Use both hands to unlock the clips that are securing the RAM.
    • The RAM will pop out from the slot when release the clip. After unlocking, slide out the RAM from their slots.
    • When inserting new RAM do not forget the put the clips back on.
Conclusão
Edward Briseno
Membro desde: 09/26/22
893 Reputação
Autoria de 6 guias
Equipe
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Membro de CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 139
