Ir para o conteúdo principal
Sony Vaio SVE171C11L Motherboard Replacement
O que você precisa
  1. Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Turn the laptop facedown.
    • Locate the battery compartment at the top of the laptop base. You will see two tabs on it.
    • Push the two tabs up to release the battery. Set it aside.
  2. Sony Vaio SVE171C11L Motherboard Replacement: passo 2, imagem 1 %32 Sony Vaio SVE171C11L Motherboard Replacement: passo 2, imagem 2 %32
    • Rotate the laptop so the empty battery compartment is now at the bottom.
    • Remove the two screws that secure the hard drive cover using a T5 Torx screwdriver. Set it aside.
  3. Sony Vaio SVE171C11L Motherboard Replacement: passo 3, imagem 1 %32 Sony Vaio SVE171C11L Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the three screws securing the hard drive disk in place.
    • Use the blue ribbon attached to the hard drive disk to carefully remove it from laptop. Set it aside.
  4. Sony Vaio SVE171C11L Motherboard Replacement: passo 4, imagem 1 %32
    • Remove all screws holding the back panel from the laptop.
    • Carefully pull up the back panel to remove it.
  5. Sony Vaio SVE171C11L Motherboard Replacement: passo 5, imagem 1 %32 Sony Vaio SVE171C11L Motherboard Replacement: passo 5, imagem 2 %32 Sony Vaio SVE171C11L Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the cables from the fan and unscrew the heatsink.
    • The heatsink has many metal pieces jutting out from its base and is located under the fan.
    • Carefully disconnect the tabs on the edges of the motherboard.
    • Unscrew the screws holding the motherboard in place. Set them aside.
    • On the underside of the motherboard, disconnect the keyboard from the motherboard.
    • Once ALL cables are disconnected, carefully remove the motherboard.
Conclusão
Edward Briseno
Membro desde: 09/26/22
893 Reputação
Autoria de 6 guias
Equipe
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Membro de CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 30
Duração total: 364
